Through Hulls |
John Mills ![]() Commodore ![]() Joined: 01 February 2016 Status: Offline Points: 122 |
![]() ![]() ![]() ![]() ![]() Posted: 25 April 2017 at 8:43pm |
Read a post somewhere else that said the factory through hulls are in solid glass on the Laser . Nice if true - anyone know if they are ?
# 164 NOTL |
Thanks - quality construction .
# 164 NOTL |
David DeBoy ![]() Rookie ![]() Joined: 07 August 2003 Location: United States Status: Offline Points: 4 |
Hi Bill,
I need to replace the thru hull of the anchor locker drain hose. The fitting broke at the interior. Storage below must have pushed against it... Do you know of a replacement thru hull fitting? Or better yet, one with a seacock? With the fitting broke it essentially is now a hole just above the waterline allowing water in the boat! |
I cannot remember what that part was. You'll have to measure the broken part to find the correct size replacement.
Thanks for the quick reply Bill! Ok, just thought I'd inquire. Will look for the replacement.
That drain is not under pressure. Just epoxy an angled pvc tube in place; diameter to fit your drain hose. js
