Through Hulls
URL: http://www.laser28.org/forum/forum_posts.asp?TID=764
Printed Date: 06 February 2025 at 1:26pm Software Version: Web Wiz Forums 11.03 - http://www.webwizforums.com
Topic: Through Hulls
Posted By: John Mills
Subject: Through Hulls
Date Posted: 25 April 2017 at 8:43pm
Read a post somewhere else that said the factory through hulls are in solid glass on the Laser . Nice if true - anyone know if they are ?
------------- Unplugged # 164 NOTL
Date Posted: 25 April 2017 at 10:00pm
Yes all thru hulls are solid glass. The entire keel grid area with instrument thru hulls, it's all solid glass and or kevlar. No foam core in that area. Same with rudder flanges and some thru hulls. Nothing goes thru just foam, cored areas for thru hulls are filled with solid fiberglass, then it's drilled out in solid material before the thru hull is installed.
Date Posted: 25 April 2017 at 10:28pm
Thanks - quality construction .
Posted By: David DeBoy
Date Posted: 11 June 2018 at 3:47pm
Hi Bill, I need to replace the thru hull of the anchor locker drain hose. The fitting broke at the interior. Storage below must have pushed against it... Do you know of a replacement thru hull fitting? Or better yet, one with a seacock? With the fitting broke it essentially is now a hole just above the waterline allowing water in the boat!
Date Posted: 11 June 2018 at 5:27pm
I cannot remember what that part was. You'll have to measure the broken part to find the correct size replacement.
Date Posted: 11 June 2018 at 6:55pm
Thanks for the quick reply Bill! Ok, just thought I'd inquire. Will look for the replacement.
Date Posted: 11 June 2018 at 8:04pm
That drain is not under pressure. Just epoxy an angled pvc tube in place; diameter to fit your drain hose. js
