I had a strange occurrence last night which I thought, at the risk of opening myself up to some ribbing, I'd relate here.
In my area, there's not much need to motor. I might motor anywhere from 2 - 15 minutes to get to the race area each Wednesday night. So the hours on my engine (since I owned the boat anyway) are minimal. I maintain it regularly though.
However last night we needed to do a 2.5 hour motor to get back to town from a race that ended elsewhere. We motored at 2500 rpm the whole way, with me periodically visually inspecting the engine (admittedly from the sides, not the front) to make sure everything was OK. I've got the two new temperature gauges monitoring cylinder temp and muffler temp as well. I also have an inline water filter between the engine and the exhaust elbow to prevent blockages.
Just before getting to the dock, we heard a funny noise and a quick check showed that the alternator belt was in the process of shredding (my motor has an aftermarket alternator installed - see pics https://goo.gl/photos/UJR7VdESqgAWXk1W8" rel="nofollow - https://goo.gl/photos/UJR7VdESqgAWXk1W8 ). Since there was nothing that could be done, we proceeded to the dock and just before arriving heard the belt let go completely.
Now, I replaced that belt only 2 years ago and we actually just retightened it a couple of weeks ago, so I was surprised it broke but it was very late by then so I left that night and returned today, expecting to simply need to clean up the broken bits of belt and install a new one.
Much to my surprise, I found engine oil all over the compartment, especially directly above the engine. NO, we were not motorsailing and the water last night was quite flat. Then I realized the dipstick for the engine oil was missing! I felt around and finally located it, just forward of the holding tank. The dipstick was quite bent.
I suspect the dipstick somehow wiggled it's way loose and got caught in the alternator belt, pulling it out the rest of the way, bending it and damaging the belt as well. The engine then sprayed oil over the belt (and engine compartment) which combined with the initial damage caused the belt to fail. In a way I'm lucky the belt broke otherwise we may not have noticed until it was too late.
Having said that, I'm unsure how the dipstick worked it's way loose in the first place. Also annoying that even with me checking the engine periodically, this still happened.
I don't think my engine vibrates too much (I mean it's a fair bit, but it's a one banger 30 year old diesel right?).
Has anyone ever had this problem before?
