Just following this thread and I will share
my experience. I put the boat in the water in the middle of June after a thorough
search I eliminated leaks from the hull/deck joint, windows, cockpit lockers
mast step, and even the vents for fuel and holding tank. After the last leak
was identified and fixed I had a dry boat……
Then in the water the boat went and still
remained dry. However I had to pull the speed transducer for trouble shooting
and some water got in the boat. After mopping up the bilge, I notice more water
would find its way to the bilge especially after sailing and heeling. I
continued to mop up thinking this was residue water slowly finding its way to
the lowest point. After the end of the weekend I was pretty satisfied I dried
up most of the water. Then I was away from the boat for 3 weeks and came back
to about an inch of water in the bilge. Hmmmm. After checking around I found
that my water tank (the portable collapsible ones) was leaking and there was
another inch of water in the port storage locker next to the galley. Okay,
there is a path for water to seep into the bilge from the locker to the bilge
via the rib. Again I moped up and dried up. At first I continued to see a noticeable
accumulation if water, but as the weekend progressed and my constant, almost obsessive
monitoring and a roll up paper towels, the leak, er, I mean accumulation slowed to an
almost non-existence.
Now this sounds strange, but a little water
kept seeping out the silicon hole between the first and second keel bolt. Not
much, and has slowed down to a ¼ teaspoon per hour. And the third keel bolt
looks to have a little water seeping around the square washers, but I am
thinking this is water coming out of the access hole which goes through the
rib. I have dived under the boat and looked for any signs of cracking or crazing,
I found none. And I did do a little bit
of fairing and bottom paint to it this spring which I notice no problems.
Being that no one has ever seen the problem of water leaking through the keel bolts, I don't think this is what happening, however it's unsettlling to think about when you are heeling at 30degrees! I will be back on the boat for a week,
starting next week, so I will continue to monitor and mopping. I suspect as the
water is removed the accumulation will cease and once again I will have a dry
bilge, at least until I spill the rum….
Then my next plan is to check the nuts, which
means removing one at a time, greasing and re-tighten. If I still have water
coming from the silicon hole, I am thinking of carefully remove the silicon and
drying out the hole. If I don’t do this while the boat is in the water, I will
do it September when I am back on the trailer, I just want to ensure I have the
keel bolts dried out before the winter sets in and creates bigger problems.
Mark Gilmore
Commodore,
SFSA
Flathead
Lake, MT
S/v Seawolf
“Those who
say it can't be done are usually interrupted by others doing it.”
http://www.brainyquote.com/quotes/authors/j/james_a_baldwin.html -
