laser 28 hull #191 for sale, 1985
Forum Name: General Forum
URL: http://www.laser28.org/forum/forum_posts.asp?TID=825
Printed Date: 06 February 2025 at 12:04pm Software Version: Web Wiz Forums 11.03 - http://www.webwizforums.com
Topic: laser 28 hull #191 for sale, 1985
Posted By: Virginia H.
Subject: laser 28 hull #191 for sale, 1985
Date Posted: 29 August 2019 at 3:54pm
asking $20000.00, almost total rehab. new Beta 14 diesel 2013, 208 hours ,new cushions 2013. mostly North sails, #1,3di genoa 2017, radian main 2017, #3,3di 2018. two spinnakers good racing shape, has another older spin. and hardly used asym. spin., 3 older #1, 3dl, pyi shaft seal 1" ss shaft, brz. strut martec folding prop,3 gal water heater, hot and cold water pressure, new faucets,20 gallon water bladder tank, new spin. pole, awlgrip hull. deck and mast. new plexiglass windows, fiberglass forward hatch, crew can jump on it. ches phrf 138 spin, cr 141, non spin 141, non spin cr 144, have short pole for non spin. 2013 new teak and holly floor boards, glassed on bottom so they will not rot. raritan phii head with 10 gallon holding tank. call Andy Armstrong, cell # 757-679-1704, or email armstronga0711@gmail.com.
Date Posted: 29 August 2019 at 6:34pm
items i forgot about, 2013 Signet depth and speed, 2013 ritchie compass, life lines replaced. new stanchions , rewelded bow and stern rails, harken adjustable genoa tracks, new Igloo cooler. new ss sink in head, new alum. spinnaker pole with composite ends, weights 7 lbs. reinforced stanchion bases, new mooring ss cleats
Date Posted: 17 November 2019 at 3:32pm
I have trader the Laser 28 in for a Tartan 101,2015. The Laser 28 is on Yacht World under Crusader Yacht Sales in Annapolis, Maryland. The point of contact is Mike Titgemeyer at cell 410-703-7986. His email is "mike@crusaderyachts.com." He is asking $17500.00. The Laser 28 is a great boat but my wife and I wanted a newer boat with more room. Good Luck.
Posted By: David Utzschneider
Date Posted: 06 December 2019 at 8:45am
I just bought this boat, had a great sail in 15-30 knot southerlies from Annapolis to Baltimore with my two college-aged kids, everyone is excited about new sailing adventures next year.
Posted By: Ron Waterson
Date Posted: 06 December 2019 at 9:53am
Congrats David! That sounds like a nice brisk first sail with her.
------------- Hull 147 - Angel's Share
Date Posted: 06 December 2019 at 9:55am
Welcome David, great way to start the season!
Posted By: GIGGITY
Date Posted: 16 December 2019 at 7:30am
David, will you be sailing out of Baltimore? There are two of us with Laser 28s on the Magothy River.
Date Posted: 16 December 2019 at 2:22pm
For now plan is to keep the boat at Anchorage MArina in Baltimore, and maybe join the Baltimore Tuesday night series, just need to get a crew and spray some WD40 on some pretty rusty racing skills; I'm more of a boat fixer than racer but that's exactly why I bought the boat. Sold a Fountaine Pajot 40' catamaran and am enjoying the 90% decrease in maintenance budget.
Posted By: GIGGITY
Date Posted: 17 December 2019 at 6:22am
Very nice! I usually try and do a couple races to Baltimore each summer. Hopefully we'll see you out there next summer!
Posted By: Marc97gt
Date Posted: 17 May 2020 at 6:30am
David,
Congratulations
on the L28, it is a fun boat to sail. I am the other L28 on the Magothy River. As you have
maintenance questions, please reach out on this forum, the support is great.. Just a few maintenance suggestions,
- Bukh
doesn't make the DV8/10 sail drives anymore so consider a zinc based bottom paint. The drives are prone to galvanic corrosion up inside the cavity in the boat as are the Gori props. Keep a few layers of barrier coat on both and use the zinc paint to control corrosion. I mounted some zincs up in the cavity by the joint to the motor.
.-Alan Hutton <sales@huttonwinches.com> has replacement parts for your maxwell Winches. he is in Australia and is very easy to work with.
- Boatzincs.com carries the saildrive anodes for around $24 - Check the tightness on your keel bolts, they can loosen up over years of sailing. A good snug with a breaker bar and sealant under the heads prevents cracks in the keel joint. -Add a raw water filter if you don't have one. I lost the original plastic muffler just outside of Annapolis due to a blockage sucked up under way.
-Add a 10A fuse to the Stop solenoid black wire at the control panel as Bill Layton suggested. -If your rudder post top casting wobbles, Bill's tip for a fillet of epoxy putty inside of the casting where it meets the rudder post, while in the yard works like a charm. Have fun Marc
Date Posted: 17 May 2020 at 7:43am
the previous owner put in a beta marine diesel with a shaft well installed great little motor, the rest of the suggestions make sense and are added to the todo list. am definitely going to be glass/epoxy the inner frame structure that takes the load from the standing rigging. will be rewiring the boat as well, and MAYBE sailing it up to Maine next summer, we'll see.
Date Posted: 20 May 2020 at 6:40pm
David,
Just a heads-up. All of the original wiring is tin coated copper strand (except for the lightning ground package)... the proper standard for marine wiring. The real problem we see on L28's is the wiring that gets added after the boat is sold. If you cut a wire or replace a terminal the original wire is tin colored it's good as long as it's not copper color. Any wiring you see that is copper should be removed and replaced with the proper tin coated marine wiring. Hope this helps,
