ORR-EZ |
Page 12> |
Jamie
Topic: ORR-EZPosted: 09 September 2020 at 6:54am |
Has anyone received an ORR-Ez Certificate for their boat yet?
I was planning on doing a local regatta in a few weeks and found out that they are only racing to this rating rule. |
Ron Waterson
Posted: 08 December 2020 at 10:44am |
Hey Jamie,
Did you get an ORR cert? I've been looking at the Offshore Racing Rule website, but haven't seen a Laser 28 recorded yet. Just curious about the numbers. Ron
Jamie
Posted: 08 December 2020 at 11:18am |
Here is a link to my rating online...
https://www.regattaman.com/cert_form.php?sku=h-1-2020-1617-11548-0-579 Generally, it slotted me in the same place as my PHRF rating with respect to other boats that I was racing against. |
Ron Waterson
Posted: 08 December 2020 at 1:44pm |
Awesome. Thanks. Just went with the Lapper for rating? I think thats a good move. She goes to wind so much better with the lapper.
John Mills
Posted: 09 December 2020 at 5:20pm |
I notice your rating is for a headsail with no roach - What headsail are you using? The class lapper has a lot of roach , the lp you state is kinda between the genoa and lapper (max LP on the lapper is 3.12 M - you running something different ? I hear some guys cut a #2 for the boats or is it you are cut for a furler ?
Never dealt with the Orr rating before so just curious .
Jamie
Posted: 09 December 2020 at 5:59pm |
Hi John,
I'll be honest with you, when I filled out the ORR-EZ form I didn't read the question carefully enough. I just assumed the roach question was about the main. I probably need to fix that for next year. When I bought the boat last year, it came with a 2010 vintage lapper from Doyle (I believe made in Montreal) that was in barely used condition. I just had the battens converted to vertical and sailed with it that way so that I can put it on the furler. I sail in predominatly light air and the cloth weight of the sail is just too heavy. My intention is to purchase a new lapper this winter. I would like to buy a new sail from Evolution as I would expect that they are making the fastest sails (as they they are supporting a very active one design class). I want a sail that can be rolled up when racing (ideally horizontal battens) and cloth weight suited for < 15 knots (I will use old lapper in stronger wind). When I was talking to the people at RBS battens they indicated that their product can be used horizontally on roller furlers. Not sure if Evolution will build me a sail with latest design and horizontal battens, but that is what I am looking for. Any thoughts are appreciated. Thanks.
John Mills
Posted: 10 December 2020 at 5:32pm |
I am told you can not support the standard Lapper roach with vertical battens. I am sure your sailmaker can work with it . Now if you are measuring for the Genoa it I believe has no roach . Mains can also have a ton of roach but the older north one seems to not but the boom is lower .
Anyway I am no expert on sails , I just noticed the #'s were off .
Ron Waterson
Posted: 10 December 2020 at 8:34pm |
I have a roller furling carbon lapper, with roach. Vertical battens. Can be done. Sailmaker can build in roach, but roller furling will take away a little sq. ft.
John Mills
Posted: 11 December 2020 at 8:17am |
Nice - certainly PHRF legal . One day I may contemplate that .
Jamie
Posted: 11 December 2020 at 11:35am |
Thanks Ron.
Who built your sail? I believe if you use the RBS battens you can have horizontal battens and the full roach.
Ron Waterson
Posted: 11 December 2020 at 2:28pm |
I actually have two roller furling lappers. Both with vertical battens and roach. My boat came to me with a cruising lapper built by Mack Sails. It's a good, dacron, hardy sail. Has the sacrificial sun cover material at the leech so it can be left on without a cover. It might be better cut sail than my race lapper, but dreadfully heavy. Haven't had it on in a long time.
The carbon lapper is by Doyle. Since the Doyle purchase, I have established a relationship with a North Sails sail designer, so I'm likely to go with NS next time around. I currently have a carbon main as well. The main is six years old and is showing wear/tear at the leech. I'm getting a 3Di Raw main from NS to replace the Doyle carbon main. If you have sailmakers locally, thats a great asset. We do not have anyone here in Louisville. BTW - I have a carbon genoa too, but I'm not likely to ever purchase another genoa. In my opinion, the balance of the boat and pointing ability with lapper far out weigh the sail area advantage of the genoa on our boat. We always use the Lapper. We do well in the small, local pond.
John Mills
Posted: 11 December 2020 at 5:19pm |
I have a 3dl genoa - crap sail , very disappointed in both the sail and the service and I probably wont ever go back to one or buy from North ever again . We have a number of local sail makers that are good but with a small class fleet I work to stay class legal . So Dacron main and lapper .
Ron Waterson
Posted: 11 December 2020 at 7:06pm |
Yeah...I think the early days of 3Dl were shaky. I have read other comments that agree with you. It's a totally different product now.
No OD issues here. There is one other Laser 28 racing though.
Ron Waterson
Posted: 11 December 2020 at 9:15pm |
Jamie,
You know, this correspondence made me go look at some photos of my lapper under sail. I'm back peddling a bit on what I wrote earlier. Apologies. There really isn't as much roach on my Doyle lapper as I was thinking there was. I have not measured the sail. The quote says it is 166 sq. ft.
Ron Waterson
Posted: 11 December 2020 at 9:27pm |
Have a look for yourself.
![]() https://www.amazon.com/photos/shared/ItTw2p2WRNGkLLut5uBKWw.HhyF5frne6XtOwrvCytTFw
Edited by Foghorn - 15 December 2020 at 4:18pm |
John Mills
Posted: 15 December 2020 at 3:08pm |
My 3dl was about 4 years ago , never was good from day 1
John Mills
Posted: 15 December 2020 at 3:15pm |
Sail looks great , more roach than you think . It goes near straight up to the spreaders then in . That is how it is supposed to be. You PHRF will be accurate . No worries at all BTW , not nit picking was just trying to understand the measurement and would love one day to go to a furler so anyone that has one I pay attention to . Great looking boat . Love to see you down this way again - will see when we get it all back together .
Foghorn
Posted: 15 December 2020 at 4:06pm |
Here's good look at the roach of a class legal lapper, this is an Evolution sail.
Decompression CAN 214 |
John Mills
Posted: 15 December 2020 at 5:43pm |
Nice picture , the roach is quite large on the lapper . How do I post a picture and I will post one of mine .
Jamie
Posted: 16 December 2020 at 2:05pm |
Ron, that is a good looking sail. It doesn't have quite as much roach as the Evolution dacron lapper, but it is close.
I mean if you compare the roach in your sail to the megles 24/20 or whatever is below you in that picture, you have much more. Although some may say your sail has more twist. The twist is great to have in a light air venue which is what we have in Boston all summer long. I am going to check with Evolution first and see what they would build me for a lighter air lapper. Ideally they would mimic the latest design of OD sails as closely as they can. Does anyone know how often Evolution updates their L28 sail design? I was very active in the Rhodes 19 class in Marblehead for many years. Doyle was the sailmaker of choice. They would update the designs of the sails every 2 years or so. But we were all buying new sails every 2/3 years.
Page 12> |
