Discussion Forum Login IMPORTANT |
Yikes
Joined: 24 January 2011 Location: Kansas City Status: Offline Points: 2 |
Topic: Discussion Forum Login IMPORTANTPosted: 27 February 2011 at 6:19pm |
Thanks Bill. Thats what i needed to know. Hope all is well with you.
Posted: 26 February 2011 at 3:45pm |
Hi Jim,
No plans. They were built by a trailer manufacturer that did them for a lot of sailboat builders in our area. Unfortunately they are long out of business. However copying an existing one is easy. Just remember to use 4" drop axles like the original so max height is kept to a minimum. Axle rating should be 3500 LBs per axle and both axles should have brakes on them. Hope this helps. Cheers Bill |
Yikes
Posted: 26 February 2011 at 2:46pm |
Bill, this is Jim Kennedy from Sheboygan WI. I am now in Kansas. I was wondering if you have or know anyone that has plans for the trailer. I am going to build one. I have a local trailer for a Laser 28 that i have been coping, but thought I should check with you to see if you could have the original plans. Anything you know will be appreciated. Jim
Posted: 06 September 2009 at 5:34pm |
This discussion forum uses its own username and password. Our website also uses its own username and password! They are distinctly different logins. So if you are having trouble this may be the reason. Hope this clears things up.
Edited by Bill Layton - 14 February 2015 at 3:22pm |
