Warbird gets new heat exchanger |
George S.
Joined: 05 December 2002 Location: Vancouver Status: Offline Points: 43 |
Topic: Warbird gets new heat exchangerPosted: 17 September 2013 at 10:12pm |
She will be WarBird again when Frank & I have finished the fun stuff !! :-) I have a template I've made from an old photo that will use the same typeface. Graphics is my biz so that was the easy part.
Harder part was grinding out all the old bonding 'filler/epoxy' (?) under the floor grid that was not bonded anymore after the grounding. No surprises here, I knew all this before I purchased and went through it with Voila too. But this time I am re-glassing all the hull grid sections with 3 layers of overlapping Knytex cloth and epoxy. The the entire area between the box sections is filled and the tabs covered completely, so the bond is as if the box sections are integral with the hull, not epoxied to them by only the width of the tabs that sit on the hull. Might be a tad heavier, but it's under the waterline... and she will be strong !! It is always interesting when two owners like Frank & I have as much fun fixing boats as sailing them. I am sure people in our club think Frank owns both boats as he is often on WarBird, not just fixing something... but making it better. Having both boats next to each other on their trailers in the dry sail area makes it easier. cheers, George |
Posted: 11 September 2013 at 9:57am |
Thanks for your suggestion and compliments to the project. |
Posted: 11 September 2013 at 9:05am |
Frank you should consider selling these as kits for people to retrofit to their boats. Very useful for the salties.
Posted: 11 September 2013 at 12:00am |
We have been using antifreeze that does not specify dilution. I suspect similar as to what goes in most cars or other diesel engines. I'm not sure of the name. I think my HE has been installed for 3 or 4 years and I've only done a complete flush once, and that was when I just took it off to convert the mounting to be similar to Warbird's. Last weekend I had to motor both two and from a regatta that was 3 hrs 15 minutes each way, and now there is no vibration on the HE. Before, when mounted on the engine, the vibration kept wearing down the padding between the HE and its mounting cradle, no matter what kind of padding I used it tried to ware through it. That is why I went to the mouldable polyurethane this time, but I'm finding that it is probably overkill, since there is no such vibration in the new position.
Posted: 10 September 2013 at 11:22pm |
Do you use a 50/50 mix of prestone or just fresh water?
Posted: 10 September 2013 at 11:14pm |
You are registered member Warbird or else you wouldn't be able to post. That message was only for non members who haven't registered (they can still read the board but cannot post messages). Current membership doesn't change.
Edited by Bill Layton - 10 September 2013 at 11:16pm |
Posted: 10 September 2013 at 11:05pm |
Warbird remains Warbird. I haven't heard George mention anything about a name change.
Posted: 10 September 2013 at 10:19pm |
Sweat installation. Is the boat again "WarBird"?
Got a post about reregistering on the forum. Bills e-mail adress came up as a link to some third party. I enjoy the forum and offering what I can in tips or advice (mostly bad) and hope to stay a member. Wicked (fka WarBird) |
Posted: 09 September 2013 at 10:48pm |
Nice work Frank! You can add your comments between the pics. Just click on Post Options, then edit.
Edited by Bill Layton - 09 September 2013 at 10:49pm |
Posted: 09 September 2013 at 9:30pm |
Warbird, recently acquired by George Streadwick, ex-owner of Voila (1998-2003) gets fitted with the 2nd heat exchanger ever done for the Bukh DV 10. Warbird's engine had never seen salt water, and George was keen that it never would. As one would expect, the 2nd installation of this innovation was better than the first. Biggest improvement was mounting the Heat Exchanger to the two vertical 1 1/2" x 1 1/2" tubular aluminum columns each side of the steps at the front of the engine. Voila had mounted her's on the engine angle steel mounting unit where it experienced substantial vibration and made it difficult to prevent the wearing of the cushioning between the HE and the mounting brackets. Warbird's installation was so nice, that Voila followed with the modification to the same. Warbird's install turned out really sweet. San Juan Engineering custom built the Heat Exchanger for $289, and a new Johnson pedestal mounted impeller pump was found on Ebay for $180. I machined the two pulleys and made up the mounting brackets using 3/16" x 3" x 3" angle aluminum. Again we relied on the engine's own female threaded bosses on the port side of the engine, though one of the bosses used is not tapped at the factory (but is there) and we had to tap that to 8mm to take up the mounting. Plumbing arrangement Edited by frfletch - 10 September 2013 at 4:05pm |
