  New Posts New Posts RSS Feed - Interior "paint"?
Interior "paint"?
WJRyan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WJRyan Quote  Post ReplyReply Direct Link To This Post Topic: Interior "paint"?
    Posted: 03 June 2010 at 7:28am
Greetings all. Finally getting last summers hit repaired and the in/outside are glassed and sanded and my question is how to finish the interior - paint or simply resin?
New toe rails are soon to installed and I will post pictures and steps I use (and will soon have 4 originals to sell if anyone is interested!) Thanks all, :)bill ryan
Bill Brock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Brock Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2010 at 10:45am
Hello Bill,
How you finish the inside will depend on the level of damage. If the laminate is fractured, meaning it is cracked, in which case fibers may be damaged inside the surface of the laminate, I would recommend an FRP repair with cloth and resin. If not, paint will work just fine. Remember resin just bonds load carrying fibers together and has very little strength by itself. Just applying resin to the top surface of the laminate will not add strength and under load it will almost certainly crack in the exact same place it cracked previously.   If you are in doubt of what you are looking at, e-mail me some pictures.
Bill
lsr28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsr28 Quote  Post ReplyReply Direct Link To This Post Posted: 10 June 2010 at 9:44am
Hi ! can you PM me I am interested in your remaining toerails.
Thanks!
This page was generated in 0.297 seconds.
