Engine Starting Rough |
Geoff Coke
Joined: 18 October 2018 Location: Rossland BC Status: Offline Points: 22 |
Topic: Engine Starting RoughPosted: 06 August 2024 at 12:54pm |
My engine has recently been starting rough?
Symptoms: - turns over 2 or 3 time more than typical before catching - significant black exhaust after it catches Does the DV8 come with glow plugs as the symptoms suggest the diesel is slow to "ignite". I could not find any reference in the manual.
Posted: 06 August 2024 at 1:14pm |
Hi Geoff,
No glow plug. Some bad fuel comes to mind. Maybe you're getting to the bottom of the tank or recently added some bad fuel. I use so little, it's a challenge to keep fresh fuel in the tank. I start with batteries 1+2 for max revs. Does the exhaust clear up? I hope it's not an injector problem. And is the air intake clear/clean. john |
