alternator |
Topic: alternatorPosted: 01 September 2006 at 1:34pm |
Hello. My alternator seems to have stopped working. Has anyone else had this problem?
Posted: 01 September 2006 at 4:12pm |
Hi Dane
I tought the same thing last year only to notice that the radio was slowly draining the battery since it had a continued feed and was bypassing the instrument panel. Also, I noted that the motor has to run at high speed for the alternator to charge reasonably and to motor to and out of the marina would not be sufficient. No problem ever since. Andr� |
Posted: 02 September 2006 at 8:39pm |
Hi Andre, Thanks for the repy. I will check alternator at cruise RPM, I have not done that yet.
Dane |
Posted: 20 September 2006 at 10:36am |
Hi Guys, Last year I experienced a problem when my Amp Light would come on when the engine was at idle. At any setting above idle the light would turn off. I called North Jersey Marine (973-546-6377) and they gave me instructions to check out the problem. It turned out to be a problem with the Charging Regulator (Page 48 in Owner�s Manual, Item 1). I replaced it and the alternator has run fine ever since. North Jersey Marine was most helpful. |
Posted: 25 September 2006 at 3:32pm |
Quote: Originally posted by Bill Brock on 20 September 2006 |
spatter
Joined: 22 November 2010 Location: Cambridge Kansas USA Status: Offline Points: 2 |
Posted: 22 November 2010 at 11:03pm |
Hi we have the same problem about alternator hope to get a really great information that can solve our problem..thank you for posting this thread this will help me a lot |
