Bare-wire lifelines |
Topic: Bare-wire lifelinesPosted: 27 June 2005 at 11:44pm |
We recently replaced our lifelines because the plastic coating was cracked in locations. We replaced them with uncoated 1x19 SS wire (slightly larger dia. than 1/8" so it's easier on the hands). Note that SS can experience crevice corrosion wherever the plastic coating ends, even at the terminals of new lifelines. I recommend the class rules be ammended to allow uncoated lifelines to avoid this situation.
Posted: 28 June 2005 at 1:34pm |
yep thats one of those things we could probably look at. I'm in freshwater and never seen any corrosion but I regularly see broken strands of wire where the wire passes thru the aft stanchion.....at least on the racing boats where the lifelines do get a workout.....this is what forces lifeline replacement in freshwater
