  New Posts New Posts RSS Feed - Water proof
Water proof
Guests View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Water proof
    Posted: 07 May 2004 at 11:31am
Hi all
We are just about ready to go in the water and have spent agreat deal of time water proofing our boat (windows...).
We have water coming in from the deck to hull joint and we have removed the inside caulking joint.  Does anyone know the proper caulking to use ?  Also, it was somewhat of a suprise to see that water was coming from the joint and we find it strange that the joint does not appear to be sealed underneat the outside rubber molding.  Has anyone tried to seal the joint from the outside, which would appear to be a better solution.
Andr�
Still Crazy 229
