  New Posts New Posts RSS Feed - mast halyard sheaves
Guests View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: mast halyard sheaves
    Posted: 19 June 2006 at 11:39am
good to know because I need to do the same! Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 09 June 2006 at 5:15pm
I found out the bolt on the mast base does not have any nut on the end and the old sheive can be taken out easily. I replaced it with a 2" X 1/2" metal sheive with a bearing in the center. The fit was perfect. I would recomend that you use a breaker bar and loosen the sheive bolts at least once a year to clean and grease the bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2006 at 12:41pm
According to the people over at E.B. Spars the original shives at the base of the mast are no longer in production. They didn't have an answer either.
I too need to replace one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2006 at 4:16pm
I need to replace halyard sheaves at mast base. My trip to local boat store didn't find any compatable size. Does anyone know the brand/manufacture for replacement shives in the mast base or specs for replacement sheaves?
This page was generated in 0.219 seconds.
