Speed measurement tools |
Topic: Speed measurement toolsPosted: 07 September 2009 at 10:27pm |
So my knotmeter has died and there seems to be no replacement for it so I am interested what the fast folks use. GPS systems? Which ones? where did you mount them - what are the challenges fo installation? As I try to learn this boat I am flying blind so any guidance would be most welcome! :)bill
Posted: 08 September 2009 at 8:27am |
Depends on your budget Bill,
I've had knotmeter failures on 2 different boats and in both cases I did a google search and found the manufacturer. In both cases the technician told me I could send parts in for verification and options for repair or discounted replacement. That said, my knotmeter is on the fritz again. Maybe it was damaged when we were surfing at 16.3 knots. Anyway, you should have a handheld GPS regardless of your knotmeter situation and that will get you by for a little while. If you end up replacing your knotmeter, I would get equipment that can be integrated to create a system. Then you can add on instruments for wind speed and direction if you want. Again, if you contact the manufacturer of your existing unit, they may give you a discount on an upgrade. john |
Posted: 09 September 2009 at 7:33am |
Standard Communications made it and they no longer are in business making marine tools - no lucj with search engines, couple of local boats places, and even West Marine techs (who have been helpful in my past liffe). So fixing it seems to be a dead end alas. I would love to hear from others who have put in some type of system and what they liked/disliked. My challenge with a handhled unit is my sterring is already bad enough..... :)bill
Posted: 09 September 2009 at 10:00am |
My 2-cents.
It depends on what you are using it for. A GPS is ok if you are navigating but if you are trying to race you really need speed through the water (defined as boat-speed) from a log transducer. The reason is twofold. First, GPS speed isn’t sensitive enough. Second, GPS speed is S.O.G. (speed over ground) which isn’t really what you want to help you steer correctly. S.O.G. includes current effects. By the way, for similar reasons the GPS shouldn’t be used as a racing compass to keep track of headers and lifts. GPS isn’t sensitive enough and it provides C.O.G. (course over ground) not heading. I have a classic Nexus system with speed, wind, wind direction, and depth. I also have a KVH “Sail-Comp” electronic compass and a simple hand-held GPS. Both the electronic compass and GPS are tied into the Nexus system. For racing, the most important data to use while steering is the boat-speed and compass heading. I only use the GPS to tell me distance and direction to the next way-point because our marks can be hard to see. The wind data is interesting but not really necessary for the type of racing we do. The boat came with Nexus and KVH. I only added the GPS. If I were to do it over again, I’d look at both the Tactic and the Nexus II. I believe both are “wireless” and therefore are much easier to install. In both you can start simple, with the log transducer and depth only, and add elements on as you see fit. In either case, you can very easily send a single from a hand-held GPS. Since it’s much easier to enter information on the hand held GPS than into the Nexus or Tactic instrument packages, I would not bother with the Nexus or Tactic GPS transducer. |
Posted: 09 September 2009 at 4:24pm |
khardy has it right.
We've used GPS against the Knotmeter to detect foul current and sail out of it to gain 1 kt over ground. Huge difference in a 20 mile race. Drive, watch heading on compass and boat speed on knotmeter display, let your crew watch the gps (Handheld). It keeps thier head in the game. Instuments are expensive so buy what you need. I have a WestMarne knotmeter and Tactic, both came with the boat, a handheld gps garmin 12(?). If you think you want wind instruments consider what ou need them for. If the boat is tipping change headsails, if it tips still, reef main. The mast head windex tell me where the wind is coming from!! WarBird |
Posted: 09 September 2009 at 4:54pm |
Yea, agree,
I was itchy to upgrade my instruments until I saw the price tag. So I sat myself down and said justify what you need. Depth gauge, knotmeter, GPS, timer, compass... good to go. john |
Posted: 10 September 2009 at 7:37am |
So what did you chooose fayjohnz?
