Rudder |
WJRyan ![]() Commodore ![]() Joined: 12 February 2008 Location: Louisville, KY Status: Offline Points: 230 |
![]() ![]() ![]() ![]() ![]() Posted: 02 May 2016 at 10:34am |
So it was the bushing and the article did help. I wasn't sure what to get so I have a thin, a medium and a thick bushing "in stock" should anyone be in need - let me know! - bll
Yup, must copy entire link if you want it to work..... operator error! So this isn't stiff and it has dropped down so I am guessing the bushing(s) have worn out and/or cracked. I plan to take it apart in the next week or so so if i need to replace the bushing(s) any idea on where I can get them?
Try the link again because it works. Perhaps you didn't copy it all before you tried it?
Thanks Bill, as always generous with the info. I tried to follow the link but it gave me an error. The UHMW bushings, where can I obtain them? Let me know and thanks again! - bill
Have a look here Bill
http://www.laser28.org/forum/forum_posts.asp?TID=9&title=l28-rudder-solutions It looks like some of your plastic washers on top may have worn out or broken off.
Spring is almost here and as I began cleaning the bottom I noticed the rudder seemed to have "slipped", there was maybe 1/8" of shiny metal showing where I had never seen shiny before and I could push the rudder up so I am guessing a gasket or something has decided to not sail another season. Suggestions on repair? Thanks, - bill
