spinnaker dimensions (again) |
![]() ![]() ![]() ![]() ![]() Posted: 14 June 2007 at 10:48pm |
Hey, Same PHRF rating for me. I get a -6 penalty off of a base 135 phrf for using that (stretched) OD spinn. We race on the Hudson River, NY. Our regional handicapper has a Laser28 so I asked what size is zero penalty. I'm guessing its that handkerchief I sold after I bought the boat ;-) My pole is 11 plus the ends. Sounds like I've got the right size symetrical spinn. Maybe I should be thinking of an Asym first. Thanks much for your info and comments. john |
Guests ![]() Guest ![]() |
I race PHRF almost exclusively. Our rating for Lake Ontario is 129 based upon one design configuration. Sounds like your spinnaker is probably one design size that has stretched a bit with use? Where do you sail? Are they basing the Laser 28 rating on One Design data from other boats or just trying to calculate a number? Some PHRF regions consider the standard L28 spinnaker pole to be oversized and penalize for its length (greater than J). Doesn't make sense to me as they are part of the boat's design and performance history. |
Hi , thanks, My spinnaker length is 34.5ft measured down the centerline and the max girth is 20. I have not checked the luff. I appreciate your pointer to a OD spinn. I race PHRF so I'm curious what size/weight the PHRF racers are using too. john
Class rules for One Design spinnaker are: Max Luff 33 ft Max Girth 19.6 ft. -By length do you mean luff or centre line? Shoulder is probably your max girth. Seems like your kite is a little oversize for the OD rating. If you want to order a replacement L28 OD spinn, I believe the Quantum Toronto loft has one in stock. I just got a new one last month from them. Nice sail. |
I've read the posts on spinnakers but they did not quite answer my questions. My spinnaker length is 34.5 feet and my shoulder width is 20. I listed the square footage as 670sqft which I'm not sure is correct based on previous postings. I'm taking a 6 second phrf penalty for have a 208% spinnaker. The spin looks to be all purpose weight. Do you have any comments on above stats? When I order a replacement, what should I get? thx, john |
