Aideas on mast electrical connection? |
Topic: Aideas on mast electrical connection?Posted: 11 October 2010 at 7:20am |
Greetings all. I am wondering if anyone has come up with an alternative for the connector at the base of the mast for the lights. WHile I appreacite the idea the placement seems to be perfect for kicking, stepping, stomping... well, you get the idea. I was thinking of pulling the line to the back of the mast and using a trailor flat 4 connector and attaching it under the vang. I figure someone has found a better way so I turn to you all for guidance! Thanks, :)bill
