  New Posts New Posts RSS Feed - Crinmar Bukh dealer in Ontario closing
khardy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote khardy Quote  Post ReplyReply Direct Link To This Post Topic: Crinmar Bukh dealer in Ontario closing
    Posted: 22 September 2017 at 11:23am
Water pump and impeller is not a Bukh part - I got mine from Depco in Clarwater FL.
Ron Waterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Waterson Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2017 at 8:17am
I have corresponded with Keith at Crinmar and he said he would place a last order in late October for early November delivery.  He already has enough orders to meet Bukh's minimum shipping requirement.
He is looking forward to retirement so let's get the orders to him ASAP.
Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Waterson Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2017 at 8:45am
Embarrassed I forgot you guys have Thanksgiving way before us/US.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2017 at 6:54pm
The 1st post in this thread states he's closing on Oct 9 - 10th so please take that into consideration. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Waterson Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2017 at 6:49pm
I'll take a look at what I need Wednesday,  but I won't be ready to place order until Mid October.  Pretty sure I'll go for all three of the routine maintenance items.
I'll mention to the other Laser in town too.  Bill (155).
  Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2017 at 6:40pm
Is anybody getting together for a bulk order (>$600)? I'd like to order the items Bill mentioned plus a couple other things. john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2017 at 11:39am
Every day stuff:
Water pump impellers, Fuel filters, Fuel bleed screw gaskets (same as saildrive drain gasket), Zinc Annode
These parts needed for replacing the head gasket:
Head gasket
Thermostat housing gaskets (2)
Exhaust elbow gasket
Valve cover gasket
Edited by Bill Layton - 29 August 2017 at 11:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Waterson Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2017 at 11:32am
Wow.  That's too bad. Keith has been a great resource for Laser 28 owners.
Perhaps a knowledgable Laser 28 owner would suggest or comprise a list of spares that should always be on the boat?
  Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2017 at 7:44am
I just rec'd this message from Keith Strutt about his closing and an offer to help us again, please read below and contact Keith if you'd like any parts or spares for your BUKH engine.
Hi Bill,
As previously mentioned Crinmar will be closing this year.  I will shut all down after Thanksgiving.
I plan to put in 1 more parts order to Bukh before then and would like to offer you and all Laser 28 sailors the opportunity to buy whatever you need at a 30% discount.  Bukh charges $75. if order total is less than $600.   Courier costs will add approx. $100. to total order.
If order is over $1,000. Crinmar will pay courier cost.  Local shipping is extra.
If you want to put together a list of parts I will be happy to offer a quote.
If nothing is required, that is fine.  I want to thank you and the Laser 28 sailors for the business you gave Crinmar over the past 13 years.
Best regards,
Keith
Keith Strutt
Crinmar of Kingston
Edited by Bill Layton - 28 September 2018 at 5:13pm
This page was generated in 1.906 seconds.
