  New Posts New Posts RSS Feed - washer - lower sail drive
WJRyan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WJRyan Quote  Post ReplyReply Direct Link To This Post Topic: washer - lower sail drive
    Posted: 28 August 2018 at 6:24pm
Hi everyone,
Just curious if there is a special kind of washer that fits with the screw at the bottom of the saildrive, the lower unit.  Guidance please and thanks!  - bill
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 28 August 2018 at 6:43pm
Go to a local diesel shop and get a small copper round washer used on fuel systems... bring the drain screw with you. Then install it tightly with RTV gasket sealant. This is superior to the paper gasket BUKH sells. RTV sealant require that you do not put in oil or put it into the water until it has set for 24 hrs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WJRyan Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2018 at 6:45am
Thanks Bill!
This page was generated in 0.234 seconds.
