Mast Step |
Topic: Mast StepPosted: 16 September 2004 at 5:24pm |
I think you may have the wrong site. This is the "Laser 28" forum as opposed to the "Laser" forum. Having graduated from the later i recognize the problem.
If so, you shouldn't have too much problem if you don't race or sail in lots of wind. But see www.laser.org for more info. |
Posted: 15 September 2004 at 10:12am |
The mast step on one of our Lasers broke loose. I had a boat body shop fix it and now the mast sits about 1.5 inches higher in the step than it did before. What problems, if any, will this cause? Thanks |
