Spinnaker cockpit launch question |
WJRyan ![]() Commodore ![]() Joined: 12 February 2008 Location: Louisville, KY Status: Offline Points: 230 |
![]() ![]() ![]() ![]() ![]() Posted: 20 April 2010 at 7:46am |
For those of you folks who launch from the cockpit can you show/describe how/where you put the bag without blocking the access to belowdecks? It seems that if the bag is in the hatch area then you could not stand on the top step and going below would be difficult. In advance thanks!! :)bill
dmarkc ![]() Rookie ![]() Joined: 29 December 2006 Location: United Kingdom Status: Offline Points: 13 |
We have continuous lines from the companionway to the mast position (I have fixed mine to existing bolts in the coachroof from the kicker cleats near the mast - picture available if needed). The bags (one for each spinnaker) are made with 4 clips allowing them to be pushed away and under the garage when not needed. Works a treat!
We use a rail bag for the first hoist - at the start of the race, the empty companionway bag is clipped on and the likely favoured spinnaker is packed in the rail bag and placed in the companionway bag - very easy for anybody to grab without going down below. The second choice spinnaker is packed and ready in its companionway bag hanging from the continuous lines forward of the first bag. If you decide to change sail choice, the first one can be removed (dropped to the floor) and the second one dragged back into the hoist position. Just remember that when hoisting from the companionway bag, you need to sneak the guy big time (can be a problem in strong winds) and probably assist the bulk of the sail out of the bag during the halyard hoist. Enjoy! Mark Carey Poole Zorra - GBR 2028L |
A picture would help me, I just can not visualize how this works alas. Perhaps you can help me with another question as well since you mention multiple spinnakers. When I bought the boat it came with two, one the traditional "triangular" spinnaker and the second more lightweight however the look is more "oval", not as wide but longer if that makes sense. Forgive my ignorance however I do not understand the reason for the difference in cut and when would I use it? Thank you for the visual aids and explanations! :)bill
And I thought I was quite good at explaining things ;-)
Try http://picasaweb.google.co.uk/lh/photo/y_ZJ9ISo_Cv23w2gUBavDA?feat=directlink I hope the link works! Let me know if it doesn't. I can't quite work out your descriptions of spinnakers. I have a LW running spinnaker which is fuller cut ie broader at the shoulders and a heavier reaching kite which is flatter. Does that sound like your two? |
Link worked, the spin bag slides on the two lines back and forth, correct?
I do not know what an LW spinnaker is or a reaching spinnaker. One I have is very traditional in its look, even sides looking like a triangle. The other one is made of lighter material and the cut is narrower and longer (top to bottom) then the first one, it seems to be not as "broad" (left to right) as the first one and I really don't know what its advantages/disafvantages are or when to use it instead of the first one. It was made by North but when I looked on their web site I could not find an image that looked like it, I may be searching in the wrong places of course! THank you again for your help! :)bill |
Correct about the lines!
If North made them, they will have a record of their manufacture and should be able to advise you. At least that is what I expect of my sailmaker ;-) |
WarBird ![]() Skipper ![]() Joined: 25 January 2006 Location: United States Status: Offline Points: 92 |
we launch right uot of the companionway often. Pit throws it out, halyard goes up quick and the pole comes back a little. No repacking upwind, no unhooking/rehooking (snake f*&k) of sheets and halyard. We can do a poleless jibe set if needed but often it is just hoist then jibe.
