trailer dimensions |
Mike V ![]() Skipper ![]() Joined: 19 August 2012 Location: Hamilton On Status: Offline Points: 64 |
![]() ![]() ![]() ![]() ![]() Posted: 22 May 2013 at 10:40pm |
I am going op pick up hull No 182 in a couple of weeks and the deal for the trailer fell through. Can someone please measure up their trailer so I can fabricate one. I need to know the distance from the tongue to the keel. Placement and height of the posts. Any help would be appreciated. I was planning on sailing the Quebec open but this situation might make it tough for me to make it.
Mike |
The next best place to order a new trailer is from the marine cradle shop just outside of Toronto. Check with them. Last i heard they built them new for $4500.
Hi Bill
I have built several trailers including a J24 trailer. It is a pretty easy job. I just need the dimensions. I can always drive to Niagara on the lake and measure the laser cradle there. I was just trying not to make the drive. The J trailer was a day project and about $1000 to build. Mike |
Trailer is a square frame with a triangle up front -The frame itself is 5" U channel all the way round even
including the triangular frame at the front -Top edge of the square frame to the resting surface
of the keel with a straight edge is 7.25" -Square frame width (outside of frame to outside of frame)= 73.25" -Dimension from outside of wheel covers to outside of wheel covers = 95" (max trailer width) -centre of tongue (ball) to very fwd bottom edge of keel = 170" -Fwd face of front square frame beam to centre of tongue (ball) = 107" -Fwd posts welded at front corners of square frame, height = 43 -Distance apart at top where post is cut, centre of post to centre of post =43.75" -Middle posts welded on edge of square frame, height = 38.25" -Distance apart at top where post is cut, centre of post to centre of post =59" -measure from middle of front post to middle of middle posts at base=68" -Rear posts welded at edge of square frame, height = 39.5" -Distance apart at top where post is cut, centre of post to centre of post =70" -measure from middle of middle post to middle of aft post at base=65.5" - 4" drop axles Tandem axle rated 3500 Lbs each axle Brakes all 4 wheels
Edited by Bill Layton - 05 April 2014 at 11:04am |
Thanks Bill
Looking forward to meeting you in person. Mike |
Thanks Bill
That is perfect. Mike |
