  New Posts New Posts RSS Feed - Spreader mount collar
George S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George S. Quote  Post ReplyReply Direct Link To This Post Topic: Spreader mount collar
    Posted: 26 September 2017 at 1:32pm
There is a new never used spreader sleeve in Winnipeg...
Andrew Murtomaki
Laser 28 #223
Winnipeg Manitoba
amurtomaki_at_hotmail.com
Edited by George S. - 26 September 2017 at 1:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2017 at 6:00am
Besides this should be insured so any mast maker should be able to do this job properly and get paid in full by your insurer.
You are correct the mast has to be stripped of all parts under the spreader casting to re-install it correctly. If you neglect to do this you will lose your mast and these masts as they are are no longer available so you'll end up getting something else that has completely different bend characteristics. EB Spars built these masts and can also advise you. They are still in business and the owner still races a Laser 28.
http://ebspars.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote WarBird Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2017 at 11:55pm
Replacing the collar is quite a job. The bottom of the mast needs to be stripped clean it seems. Is bonding, glue, epoxy a reasonable alternative?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 8:35pm
Remove the two pieces and have a machine shop weld it back together. They can do amazing repairs on alum castings. You just have to find out who does it best in your area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WarBird Quote  Post ReplyReply Direct Link To This Post Posted: 13 September 2017 at 8:22pm
We broke a spreader mount tonite while dropping (too fast) a.mast. What are our options?
