Water pump leak |
Topic: Water pump leakPosted: 28 August 2018 at 6:32pm |
Hi all, I noticed a small drip coming from the water pump on the portside of the Bukh. Is this a process of take it out and replace bushings or gaskets? Or something more detailed? Please advise and thanks! - bill
tonyt
Joined: 11 January 2017 Location: Halifax Status: Offline Points: 18 |
Posted: 29 August 2018 at 1:39pm |
If the pump is leaking out of the weep hole it usually indicates that the bushing is wearing. I don't know if there are rebuild kits for that but there is a replacement pump from Johnson that is fitted with bearings rather than bushings.
I put one in a couple of years ago and it was about 400.00 for a new pump and clamps. Here are the part numbers: Qty Item
Part Number I subsequently found them available from ASAP Marine in the UK for about $125.00 so definitely worth looking on the web for them. It took weeks for my pump to arrive so you would certainly do better ordering from the UK. I think you also need to order a gasket for the pump but I don't have the part number for that |
Apres Ski LAser28 162
Posted: 30 August 2018 at 7:21am |
It is coming from the weep hole so I think your suggestions are right on - thank you for the links and the lessons learned!! And as a skier I really like your boat name!!
