Spin Halyard Modification |
Topic: Spin Halyard ModificationPosted: 01 August 2008 at 11:40am |
Mine has been rigged that way since before I owned the boat. Your idea will work perfectly. Good luck, always fun cutting holes in boats above and below the waterline.
Posted: 01 August 2008 at 9:18am |
Currently my boat is rigged stock, with all halyards exiting the mast at the bottom. I would like to re-run the spin halyard so that it exits on the side of the mast, 6 or so feet from the deck, so that the halyard can be "jumpped" from the mast. I plan on cutting the hole, putting in a standard exit plate, and mounting a single cam cleat undertheath it. I think this is a no brainer but if any body can think of anything I should watch out for I would apreciate it.
