  New Posts New Posts RSS Feed - Gori Propeller
Gori Propeller
micha571 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote micha571 Quote  Post ReplyReply Direct Link To This Post Topic: Gori Propeller
    Posted: 17 November 2010 at 4:39am
Thanks, I found a good used propeller yesterday.
But thanks for the offer.
Regards, Michael
Post Options Post Options   Thanks (0) Thanks(0)   Quote frfletch Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2010 at 12:21am
I have a spare gori with good blades, though I don't like the hub because there is continuity between the outer hub and the drive spindle. The blades and gears are excellent. If to be used in fresh water, no problem with the hub, otherwise fix your own hub as per my previous instructions with the epoxy, and change the blades over. I will check on the size, but I'm guessing that it is correct. I am currently in Hong Kong and won't be back in Canada until the 27th to check the actual size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote micha571 Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2010 at 12:39pm
Yes, I have read that. But in my case, it is a worn out rubber bushing and the teeth of the blades are seriously worn out, too, so that the propeller does not really fold anymore :(
So it would be a new bushing and new blades as well, and that is more expensive than a new prop. But thanks for the advice!
Regards, Michael
Cayuga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cayuga Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2010 at 12:32pm
If the isolation bushing is worn out causing the inner hub to spin freely of the outer hub/blades, it may be possible to have it repaired by sending it back to Gori. This happened to mine this summer and rather than losing the season I bought a new one from AB marine, something like $1100. Somewhere on this list is a description of repairing this condition with some epoxy and an oven. I may try that with my old one this winter.
rjuelliott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjuelliott Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2010 at 2:14pm
Yep, sorry absolutely correct, just found the paperwork it is 15" x 9, best of luck, cheers Rupert
Post Options Post Options   Thanks (0) Thanks(0)   Quote micha571 Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2010 at 1:10pm
Hi,
would be great if it is the right size. But I suspect three-bladed it will be a size or more bigger :(
Michael
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjuelliott Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2010 at 6:24am
HI, I am about to change my Gori, think its that size, may be 14 inch, will measure it up when next at the boat (saturday week), three bladed been on for two seasons, will send message once measured or paperwork found! cheers Rupert
Post Options Post Options   Thanks (0) Thanks(0)   Quote micha571 Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2010 at 10:55am
Hello,
I am in need of a good Gori propeller, size 11,5x9,5, saildrive, right hand.
Does anyone maybe have one up for sale?
Regards,
Michael
This page was generated in 0.313 seconds.
