Forum Home Forum Home > Laser 28 General > Sailing
  New Posts New Posts RSS Feed - class rule checklist
lsr28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsr28 Quote  Post ReplyReply Direct Link To This Post Topic: class rule checklist
    Posted: 13 September 2009 at 10:44pm
Hi All,
I recall comming across a class "checklist" to be signed by the skipper prior to a few class sanctionned regatta. Is there anyone aware of this checklist?
I would like to suggest to the Magog regatta organisers to have each owner sign this list prior to the race. We have seen stripped boats, overweight crews, and such lately in Magog.
I would forward this checklist to the Magog guys if I can put my hands on it.
Foghorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2009 at 11:55pm
The requirements for Laser 28 Class sanctioned events is listed in the Class Rules;
Laser 28 Class Rules link
I'm sure that everyone in Magog intends to sail by and enforce the Class Rules, it makes it much more fun Wink Thumbs Up
Class Rules will also be in effect for the North Americans in Montreal starting September 25th, just like the Canadian Championships in Magog September 19th.
Laser 28 Class Events link
See everyone on the water!!
MINIMUM EQUIPMENT and REQUIREMENTS
ITEM
REQUIREMENT
Laser 28 Class Membership
Proof of Membership for boat.
SailInventory
A maximum of one, and only the same one of each class sail, may be carried and used in a race or series of races. All sails shall be "Class Royalty Paid".
Canadian Coast Guard Approved
Anchor, 13 lbs minimum with 30m or (100 ft) Rode Stored in Anchor Well.
Safety Equipment
Lifejackets: one per person plus one extra or floating cushion.
Life buoy ring 24 in. minimum
Buoyant line 15m or (49.2 ft)
Hand Bailer: Bucket w/Lanyard
Manual Gusher pump with 1 ½" Hosing, hose must be able to reach the galley doors.
2 Fire Extinguishers
Distress Flares: Minimum of 12
Sound signaling device
One set Tapered Wood plugs
Interior Furnishings and Other Equipment
Complete Dinette Table in original location.
Chopping Board in Galley
Ice box and Dry food storage covers
Stove (installed and complete)
Fresh water storage tank: Portable is OK
Head basin installed as original equipment
All sliding panels and doors in place
All Soft Lockers Installed
All Cushions Installed in intended positions.
All Plumbing, Seacocks, Thru-hulls, Hoses, Toilet and Holding Tank and fittings installed as originally supplied.
One Battery: Group 24, Minimum
Companionway Wash boards with Minimum Thickness of 3/8 in.
All Cabin soles installed with Minimum Thickness of 3/8 in.
Anchor and Steaming Lights installed, Mast Wiring and Conduit installed.
Fuel: Minimum Quantity 3/8th Tank.
Decompression
CAN 214
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2009 at 12:20pm
This list can be used for any sanctioned L28 regatta. We did so in the past.
The safety equipment was a mirror of Canadian Coast Guard requirements at the time we last used this list.... today the CCG regulations only requires 1 Life-jacket per person aboard.
The Class Royalty Paid label on sails hasn't been in effect for quite sometime. However The rest of the L28 class rules are in effect at all sanctioned regattas. Any boat can be inspected anytime during a sanctioned regatta. If a boat is found not to conform to class rules they will be disqualified immediately.
Denise will bring the class scale should there be any disputes over crew weight.
Laser28 Class Measurer
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsr28 Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2009 at 1:26pm
Thanks all for replying, I think it makes sense to bring the scale down in Magog, might not be necessary to do a full "scale" weigh-in, but to let the people know what is the limitation and that the scale is there might be taken seriously.
Once again, I do remember seeing a list that the owner had to put a "check" in little box at then end of each line of listed items, sign it and return to the rc.
We don't want to raise anything, just let everyone know that as the fleet pick up, thing should be done properly.
This page was generated in 0.375 seconds.
