  New Posts New Posts RSS Feed - Main sheet
Main sheet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Main sheet
    Posted: 25 August 2004 at 5:09pm
I use a Harken self tacking traveller on the L28. Works great. Occassionally gets caught up in the traveller recess at  the end of the track and chips up the gel coat.  My mainsheet is a 6:1 and 3:1 double mainsheet with two cams at the bottom block. Pull both sheets at once: 3:1, just one gives you 6:1.  Works like a charm!
Post Options Post Options   Thanks (0) Thanks(0)   Quote khardy Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2004 at 4:56pm
We used a spin lock cleat on a melges 24 and i didn't like it; std harken cleats worked much better. I am also thinking of going to a cleat mounted on harken's swivel base similar to the j-24 set up. In addition to a better angle this will give more purchase.
The only thing worse than the mainsheet cleat is the traveler set up. I'm hoping i can fix this with the harken traveler set up (with cleats on the car) but i don't know if it will fit in the recesses in the cockpit yet. FYI, i race PHRF only so class rules in this are not a factor.
hope this helps,
ken
Tenacity 241
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2004 at 12:52pm
We frequently have trouble uncleating the main sheet in winds over 15 knts. It takes a big kick to release that main sheet cleat.
I have been thinking that maybe a Spinlock PX cleat would be easier to release. These are used on J105s.
Also has anyone changed the main sheet rigging to use a barney post style to replace the cleat on the moving traveller.
Any ideas would be appreciated. The main sheet is really tough on windy days.
This page was generated in 0.203 seconds.
