companion way hatch |
John Mills ![]() Commodore ![]() Joined: 01 February 2016 Status: Offline Points: 122 |
![]() ![]() ![]() ![]() ![]() Posted: 05 July 2017 at 7:54pm |
You can buy the plastic at any plastics supplier, you have to router it or use a table saw to get the grove . I forget off hand what it was , I think HDPE , Bill would know or just take one in and they will match it . As for aluminum well Andanzas did that - do a search and he may have a guy .
bal149 ![]() Skipper ![]() ![]() Joined: 14 August 2010 Location: canada Status: Offline Points: 67 |
time and sun have cracked the companionway hatch rails. I recently drilled them through with installation of a screw and bolt to get a more solid "fix" but their days are numbered , I'm afraid. I thought of using aluminum bars but machining would be pricey. Any ideas?
