Rudder Ring |
Topic: Rudder RingPosted: 11 June 2017 at 5:09pm |
Lesson learned follow up: I have replaced the rudder ring a little over a year ago but my rudder has been "weeping" water so this past fall it came off the boat and the old foam was replaced and the rudder was reinstalled. Here is the lesson I share. You can put the metal cap that cover the rudder post and allows the tiller to be attached on backwards. 2 tips to know if you did this, first if you need an extra ring/bushing where in the past you didn't and , second, if the tiller can touch the floor of the cockpit. If you find either of these clues - stop! Turn the cap around and try again. Now, should you be so silly as to launch the boat and start sailing don't worry. If you return to your launch ramp, back the boat in slowly and someone gets in the water and holds the rudder (a line under the bottom of rudder works too) you can quickly turn cap cover around, take out the extra spacer that you didn't need to buy and harmony will once again reign. - bill
Posted: 19 April 2017 at 4:37pm |
fatjohnz28 at gmail dot com
Posted: 19 April 2017 at 4:10pm |
I have a couple of the ones I did not use and if you send me an email address I will take a picture tomorrow when I go to the boat and send it to you. - bill
Posted: 19 April 2017 at 3:29pm |
Raising the rudder happens at the top end... under the rudder shaft cap there are plastic washers that fit over the rudder shaft underneath the cap. So that 3/8" gap you see is where the washers are supposed to be. If you add to many washers it lifts the rudder so there is no gap between the rudder spade and the hull and it'll make the rudder stiff because of lack of endplay. If there are not enough washers then there is a gap between the rudder and the hull and when you lift the rudder up and down (from outside you can hear it go clunk clunk which is a sign of too much endplay. Call me if your still stuck
Posted: 19 April 2017 at 3:16pm |
Thanks for sharing the link Mr.Layton. I knew I had read the topic before but couldn't find the thread.
After Mr.Ryan's question I realize that I'm not sure what I'm looking at. When I lift the rudder, there is 3/8" gap between the bottom of the rudder shaft cap and the deck housing. When I look down into the housing, I can see a dark washer. I don't see any white plastic bushing. After reading the previous threads on the topic... I'm not sure what it is I want to do to raise the rudder a bit. Thanks in advance, john |
Posted: 19 April 2017 at 6:55am |
Just to clarify the question John, are you referring to the white plastic bushing between the rudder post and the cap that the handles attaches too? If so I know where you can order them. To Bill's point they were different sizes and I had to buy 4 and only used 1 so I may have what you need "in stock" so I can share the vendor I used or send you the extras I have. - bill
Posted: 18 April 2017 at 7:42pm |
You have to have them made by a machine shop. They were different thicknesses. So you would need to measure up the space you need to fill or the broken washer. Here are the links describing what to do. They were stickies in the maintenance forum.
http://www.laser28.org/forum/forum_posts.asp?TID=9&title=l28-rudder-solutions http://www.laser28.org/forum/forum_posts.asp?TID=17&title=rudder-solutions |
Posted: 18 April 2017 at 7:25pm |
Sailors,
I remember a discussion about the ring between the rudder cap and the rudder mount. Does someone have a ring they would like to part with? I could only search the forum for the past year. When I search all-time I get an error Microsoft VBScript runtime error '800a0005' Invalid procedure all or argument: 'Mid' /forum/functions/functions_format_post.asp, line 1020 I tried loggin out and login back in. thank you, john |
