  New Posts New Posts RSS Feed - Engine Paint
Engine Paint
khardy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote khardy Quote  Post ReplyReply Direct Link To This Post Topic: Engine Paint
    Posted: 19 March 2018 at 3:07pm
Any recommendations for re-painting the Bukh?
I have the engine out and all the accessories, (hoses, water pumps, starter, etc...) removed. Now I need to repaint what's left: the crankcase, cylinder, and head. I've wire brushed all the loose paint off.
What should I use to clean the engine prior to painting? I've read online that after removing all lose paint I should de-greese the engine with gunk and rinse with fresh water and then dry thoroughly. But can't I just wipe it down with acetone?
What would you recommend for painting? I've read ceramic enamel for high temp engine paint.
Any other hints?
Winner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Winner Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2018 at 4:56pm
This is the paint to use:
https://www.amazon.com/gp/product/B000CPI028/ref=oh_aui_detailpage_o03_s02?ie=UTF8&psc=1
This page was generated in 0.250 seconds.
