  New Posts New Posts RSS Feed - Waste Deck fill adapter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Winner Quote  Post ReplyReply Direct Link To This Post Topic: Waste Deck fill adapter
    Posted: 11 August 2023 at 11:40pm
Thanks fatjohnz.  As the previous poster mentioned, the size appears to be slightly smaller than 1 1/4" male thread which I have confirmed myself.  Wondering i anyone knows the actual size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2023 at 12:11pm
This is one of many 'hose adapter' that I found on this website
https://replacementboatparts.com/products/1-1-4-hose-barb-x-1-1-2-hose-barb?_pos=12&_sid=1a2e33d39&_ss=r
Post Options Post Options   Thanks (0) Thanks(0)   Quote Winner Quote  Post ReplyReply Direct Link To This Post Posted: 10 August 2023 at 9:52pm
Hi there everyone, I'm reigniting this discussion as the adaptor I use has broken.  I went to a couple of industrial places and none has the right size.
Solutions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2006 at 12:06pm
Thanks for the many E-mail received.  Found a solution.
Andr�
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2006 at 5:51pm
Hi all
Our Marina waste pump out hose is the standard 1 1/2 inch.  I am trying to find an adapter to connect the hose to the Laser waste deck fill which appear to be of a non standard size slightly less than 1 1/4 inch (probably metric).
I know that C & C 27 Mark V have the same difficulty but I have yet to find a pratical solution by way of an adapter.  I have considered changing the deck fill plate but I cannot seem to find the same 3 15/16 inch size replacement part.  Changing to a lesser dimension would mean repainting some part of the deck... lots of trouble for a toilet we hardly use.
We even asked a local machine shop to make an adapter.  They are willing for 400 $...
Andr�
