  New Posts New Posts RSS Feed - Mast Display
Mast Display
Comet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Comet Quote  Post ReplyReply Direct Link To This Post Topic: Mast Display
    Posted: 17 May 2021 at 3:55pm
I want to mount a Garmin GNX 21 display at the mast, below the boom and the vang (mine is solid). Likely I will have to get a mount machined or constructed by a friend. Has anyone done this? Or have any bright ideas? I am wiring from the GPS below deck so I can get that detail in front of me and not where the crew seems to be all the time!
I found a bracket on the boat when I got her that looks to screw in below the boom but it is too small for the Garmin. (Figures)
Thanks for any bright ideas!
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 5:19pm
Maybe the Garmin has a see through case that you could screw onto a mast slug. js
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ron Waterson Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2021 at 8:39pm
Kydex is your friend.  Take a look at my SA post.
https://forums.sailinganarchy.com/index.php?/topic/213903-kydex-mast-instrument-bracket/&tab=comments#comment-6950209
Post Options Post Options   Thanks (0) Thanks(0)   Quote Comet Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2021 at 4:31pm
What a great looking bracket!! Looks just like the Garmin one that costs $$$$$.
Once the mast gets vertical I will get together with the elves that can handle such projects. The metal bracket that doesn't fit the Garmin instrument was made to bolt into the sail track. The custom one made for my old J27 was made to slide into the track. All great ideas by smarter people than me!
Thank you!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2021 at 11:45am
Here's how I have mine setup. This is a custom made bracket, not expensive to have made if you can draw the bracket yourself, this one cost about $60.
I drilled and tapped holes in the bolt rope groove in the mast and use 2 fasteners.
Edited by Foghorn - 22 May 2021 at 11:48am
