Lifting boat with keel bolts |
Ed Matt ![]() Rookie ![]() Joined: 21 August 2007 Location: United States Status: Offline Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 28 November 2007 at 8:09pm |
Thank you. That's just what I was looking for.
Ed |
khardy ![]() Commodore ![]() Joined: 22 June 2004 Location: United States Status: Offline Points: 132 |
Go to www.laser28.com. There are detailed instructions on single point lifting including a bracket design which attaches to the keel bolts. You'll need to get a machine shop fabricate the lifting bracket. Easy to install, you can even do it while the boats in the water. PS use a nylon sling not a chain.
I have a vent just forward of the sliding hatch. Can I lift the boat by running chain through vent hole and anchoring to my keel bolts? If so, is there anything I should be concerned about?
Thanks Ed |
