  New Posts New Posts RSS Feed - forward hatch cover
forward hatch cover
Bobs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobs Quote  Post ReplyReply Direct Link To This Post Topic: forward hatch cover
    Posted: 17 August 2024 at 2:30pm
Laser 28 forward hatch cover longitudinal brake, how to repair or replace, where to get replacement.
Advice appreciated
Bob
RJS
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2024 at 7:21am
Hi Bob,
Laser28 hatches are tough to procure. It's a custom item, I'm afraid.
What I've done is send a request to eplastics.com along with a template they can use to form the new hatch on. The person at eplastics who has responded to my requests is James Waller (San Diego).
If your existing hatch is still intact, you could send that as a template. I would add some blocking at the front and rear under the peak of the curve. I've had my template compress under the pressure which results in a slightly flatter hatch than you would want.
If your hatch can't be used as a template then what I have done is build a plug. I took a few pieces of thin Luan and cut them to hatch size. Then put the 1st piece in the hatch hole, add glue to the top and apply the next piece and so on. Then press them into position with some bricks. I've also used this plug as a hatch cover in a pinch. lol
I ruined my last plug trying to fine tune the fit. Otherwise, I'd loan it to you.
john
Bobs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bobs Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2024 at 4:26pm
Thanks for your reply. I hope to find a local fabricator when the season is over. So far, duct tape and a big red circle on the hatch cover got us through the last race. I think the hatch cover will work as a template. I may have to try eplastics.com
Thanks again
Bob
RJS
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2024 at 7:36am
If your hatch cover works as a template, hang on to it. I may ask to borrow it in the future. john
Ron Waterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron Waterson Quote  Post ReplyReply Direct Link To This Post Posted: 02 September 2024 at 9:10pm
Check the Lake Ontario Laser 28 FB page.  There are sources to have one made there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2024 at 7:08am
Thanks Ron, I've joined.
john
WJRyan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WJRyan Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2024 at 1:39pm
I had mine done ~6 years ago and the local gent who made it did a great job. Cost was $275, if you want me to connect you please let me know.  - bill
Winner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Winner Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2024 at 9:54am
Hank Prenger at P&A Plastics in Hamilton Ontario.  Had one made in 2022.  Cost was $294
Also note when getting a new hatch made, you do not need four holes drilled for the latches.  I just had the two forward ones drilled and have had no issues.
This page was generated in 0.313 seconds.
