Forum Home Forum Home > Laser 28 General > General Forum
  New Posts New Posts RSS Feed - Bukh Saildrive primary Drive gear
Marc97gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marc97gt Quote  Post ReplyReply Direct Link To This Post Topic: Bukh Saildrive primary Drive gear
    Posted: 29 November 2020 at 3:55pm
I understand this is a long shot, but I wanted to ask if anyone had a spare primary drive gear that drives the two prop gears on the prop shaft of the saildrive.
  After pulling the boat for the winter, I found murky lower unit oil, which indicated a leak. After removing the SD lower housing, I found the primary drive gear had wear damage to the center drive surface of all teeth. The prop drive gears were fine . I ordered a replacement drive gear and shims from LSM Diesel, but it was a different size and diameter (taller and a smaller diameter) than my original and had a different gear design as well. Not sure why Bukh would have multiple designs for the DV8, but the gears were different.
As stated in an earlier post, I am evaluating options for the SD. Will contact United Welding Processes to inquire about getting my gear remade, but am also evaluating the option of pulling the Bukh and SD and replacing it with an outboard off the back, like the J29's did.  I know it goes against the grain to have anything but an inboard on the L28, but reliability and budget are also part of the evaluation process.  Re-powering with a new Beta Marine sounds appealing, but the cost is hard to justify.
Let me know if there are any primary drive gears out there collecting dust.
Images of gears in attached pdf below;
Thanks,
 Marc
Edited by Foghorn - 09 December 2020 at 10:43am
John Mills View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Mills Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2020 at 9:48pm
Bugger to get that back together on the boat .
# 164
NOTL
Foghorn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2020 at 11:12am
You ordered R620A2101 Gearwheel Little Drive from LSM?
Decompression
CAN 214
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marc97gt Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2020 at 1:58pm
Paul,
I did order the R620A2101 Gearwheel Little Drive from LSM as referenced by the Bukh parts master).  My gear had wear damage in the middle of each tooth, so as a first step contacted LSM and ordered a new one from them.  As part of the order, I also purchased the rear bearing assembly, a new thrust washer, O-rings, and some shims for adjustments as required. All told ~$1500.  My prop shaft gears had minor scuffing,  just the primary gear suffered the most damage. When I  received  the new gear from LSM,  it was apparent the gear teeth height and designs were different. I can send you pictures with associated measurements if you want to compare your gear up against my old one and the new one from LSM.  If yours are in line with the new gear, it should be a good fit. I was tempted to order the two prop gears from LSM to see if they would match up with the new bevel gear, but another $2K ($1K each gear) after the first didn't match was in the guess category. It didn't make sense that Bukh should have more than one design for the gear set, unless at some point they made an undocumented design change .  At one point I did call Erik to request the refund. He was kind enough to let me send the parts back  to them after I emailed the pictures of the gears not matching up and the phone call. The refund minus $270 import duty/restock fee  and another $145 shipping with insurance was an added cost to the order.
As a plan B, I contacted Stephan Beaulieu-Champigny / Plant Manager at United Welding Processes  (514) 321-3320 or (800) 361-3950, Email Stephan@uwp.ca, and sent him pictures of the gear asking if he could repair or replace it. His response was that they would have to remake the gears to get proper alignment and meshing. My prop shaft also had minor scoring from the gear debris, so if I pursued this route, would also ask him to remake the shaft, as they are no longer available either.
I have owned the boat for 15 years, and this is the second saildrive on it. After one race in severe weather, my dog clutch came apart and destroyed the gears in the lower unit.  I replaced it with a new one from Bukh 10 years ago.
I love the boat, but after two rounds with the SD, it makes sense to me  to look at Bukh alternatives. The Beta inboard/shaft drive  solution is about $13K for parts and yard labor.  I am also evaluating outboard solutions for my 35 year old boat. As I was considering this path, I walked the boatyard to make measurements on boats with outboards, and was surprised to see quite a few with both outboards on the back and also inboard drive props poking out their bottoms.  After going through this process it dawned on me how much I have had to pamper the SD over the years, using zinc based paint that quit working the third month, buying Gori props every four to five year, and replacing the shaft seal every 7 years. After those considerations, the outboard wasn't so bad after all.
Let me know if your gears have sustained similar damage.  As stated above, if interested, I can send you pictures of the drive gears, new and old so you can make an informed decision forward if/and when contacting LSM. Just send me your email. Mine is rileys_4@verizon.net.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2020 at 4:48pm
Just so I understand correctly Marc, you replaced the complete sail drive unit with a complete new Bukh sail drive?
Decompression
CAN 214
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2020 at 5:20pm
If I ever had to consider repowering the Laser 28 I would go with a Yanmar 1GM10(C) with the SD25 sail drive. This is a single cylinder horizontal crankshaft diesel rated at 9.9 HP which means for a sail drive application it has a bevel gear transmission at the rear to adapt to the sail drive. Custom bracketing would be required for the engine mounts and a new sail drive ring fabricated, also the back of the stairs would need modification as the engine would protrude further forward. All doable in my opinion.
If you mount an outboard and race the boat then you may consider removing the Bukh, that would necessitate a block off plate for the engine well and a new rubber to cover the hole in the hull for the sail drive.
Decompression
CAN 214
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Mills Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2020 at 2:06pm
I hear the sail drive guts are the lower half of a Suzuki 25 HD outboard if that helps anyone source parts
# 164
NOTL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2020 at 2:34pm
Indeed, the Suzuki DT25 of the similar era appear the share many parts with the original Bukh sail drive. In Marc�s case he bought a replacement sail drive from Bukh in 2010 which seems to have some differences but could probably be made to work with help of a machine shop.
Edited by Foghorn - 28 December 2020 at 11:35pm
Decompression
CAN 214
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Mills Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2020 at 2:42pm
I  am not sure if these parts will fit - https://www.ebay.com/itm/254532454813
# 164
NOTL
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Mills Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2020 at 2:49pm
There is this too - you will need to figure out if they fit but cheap enough to risk it . https://www.ebay.com/itm/Suzuki-Outboard-DT-25-1983-1988-Gear-Set-57521-96311-57510-96312-57311-96310/173506242641?_trkparms=ispr%3D1&hash=item2865c72851:g:PnQAAOSwR4hbiSqR&amdata=enc%3AAQAFAAACYBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkSG%252BOFgrj2Yvbvmrj2TAdM15I37qu5Saj4rkr5R3jIyNhnNOtCIM1Uyxn1J15cJ7CDQFVXNrQZkno0MyovgC8mFqZfkZ2ciwkQQE23UFCoNmErvaDHQJCPP2gnnaddSGdStTHdbBrMFqVvQA8B0LpeGx7Kg51fi%252FQ1HIu0larRMS00s18iq1hkZ9Yf1grSWIgfQ7NFbUsJpAT4RZKwIcgu%252BbXGnOocfwyypdsifpQSeSe0cqdcByZZXntgKHl3d%252BnHhZwW7KNi16yQ%252FOCHiAH8XJCCD%252BLzIpmNhBPqLxJ3ULT7LD4TPwtu3g5Wq5gOgSdnucILgO8iLHiX%252BhlmvT%252BG8RaCBabshAGPHk%252BF%252FlxIgjIznBbFVoTiHjjhJwZmvdDvhnHhn9S1gUw8sV0Sq7zLKE5XTfY8dD2VQFXzS%252FxP56z8lg%252Fz%252F8hNSkh2QCmm8yHwN0eXxsrz06IMGB6HpWkAFzCpLUO99MsaFnC3kBQAlb8fBKRFNZbPgoMyIFFmJkhwZs8gpBX22OU2eWqSflMo7qoKcZuXkWZ2M%252BY7SWBK2PhILu3oXsKqlRw8Kbcskh4v93mIDu2yciV%252Fu80PAg35fHmjv29HyNbOofSVHdo6G32P7URJNFd42tvrBg8jii7pVsZLfF4RbQg0MPqD2mHxIi3c8vQwLbSf8g3%252Fa5OHWCbMx%252B6oTnBnVgB8RDoZsSwKM5qxsL2esY087k3fLSKmIhoKGWrbkV%252Fl8JyIItYT55pg%252BfHhoyn9KNWToAzc32c%7Ccksum%3A17350624264117a3e45c18034e959dcaebba9d6a75e0%7Campid%3APL_CLK%7Cclp%3A2334524
# 164
NOTL
