Alcohol Stove - Safety First |
Topic: Alcohol Stove - Safety FirstPosted: 02 December 2002 at 10:06pm |
The majority of Lasers have alcohol stoves. The early boats had propane stoves... original new owners were complaining that their insurers were complaining about the high risks associated with propane and were recommending alcohol instead. Accordingly, Laser switched to the Origo 3000 2 burner alcohol stove in early 1985. Although alcohol stoves are deemed safer because there are no gas lines piped below deck, they can still be hazardous. The risk with alcohol is that it can burn without being visible. While reading a horror story on "Pat's boating in Canada" site, I realized this was a must read for owners and operators of alcohol stoves. It also addresses the importance of having fire extinguishers in accessible areas. http://boating.ncf.ca/firegalley.html
Edited by Bill Layton - 16 May 2012 at 10:40pm |
Posted: 16 May 2012 at 8:23pm |
Sadly, the link no longer appears to work. I read the post previously and thought it was very useful. Too bad it's gone :-(
bal149
Joined: 14 August 2010 Location: canada Status: Offline Points: 67 |
Posted: 16 May 2012 at 8:36pm |
I am more than happy that Balaou has a propane stove-it actually heats as opposed to alcohol which is only good to drink. The insurers insisted that the tank be outside of the well where it was originally located, so I have mounted a small bucket on the stern pulpit that holds a disposable tank-everyone is happy and my food cooks quickly. Put a clay pot on the burner and it heats the boat. Turn off the propane at the tank when not in use and there is little risk of explosion.
Posted: 16 May 2012 at 10:40pm |
Link in 1st post above updated
