  New Posts New Posts RSS Feed - Mast Sheaves
Mast Sheaves
Post Options Post Options   Thanks (0) Thanks(0)   Quote khardy Quote  Post ReplyReply Direct Link To This Post Topic: Mast Sheaves
    Posted: 16 March 2015 at 4:37pm
Can anybody recommend replacement mast sheaves? I'm talking about the sheaves at the base of the mast and their counterparts up high.
thanks,
ken
Edited by Bill Layton - 13 April 2015 at 4:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2015 at 4:51pm
EBSPARS.com is the original supplier and still in business. That's where I got mine from.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Layton Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2015 at 9:17am
seems this post got buried
Post Options Post Options   Thanks (0) Thanks(0)   Quote khardy Quote  Post ReplyReply Direct Link To This Post Posted: 27 March 2015 at 11:14am
I thought I had posted this question before but I couln't find it.
thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote khardy Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2015 at 9:44pm
ebspars tells me they got them from laser and they don't have any more. I purchased some ronstans and I'll let you know if they fit.
ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote frfletch Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2015 at 10:23am
I made new ones for Vivace using UHMPE as the base material and turning the bushings from bearing suitable bronze. They have now been working for 3 or 4 years perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatjohnz Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2021 at 10:36am
Hello, Do you need to drop the mast base to service the lower sheaves? I tried to remove the bolt(s) with the mast raised and the bolts bound up. I'm thinking there is a nut inside the base. Is that correct?
thanks, john
Post Options Post Options   Thanks (1) Thanks(1)   Quote Foghorn Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2021 at 11:59am
No nuts in the mast base casting, the sheave flange is tapped.
