Rudder repair |
John Mills
Topic: Rudder repairPosted: 01 February 2016 at 6:01pm |
My rudder has some crusty rust/scale on the surface sticking out maybe 1/8 inch . I read somewhere the rudder is foam core with webbing in it . I think there must be a crack that let some water in .
My plan is to grind out the area and fill with epoxy filler and normally I would inter-protect the rudder but I read it does not stick on the L28 for some reason .
Does this seem the best route ? Any advice , anyone seen this before? Anyone inter-protect their rudder successfully? |
